Results 1 to 2 of 2
Thread: Wood stove for a wall tent
    Cold Heartless Breed tsitenha's Avatar
    Mar 2008
    Kanata
    979
    Default Wood stove for a wall tent
    I may have mentioned this before...I am making plans for a wood stove using a 30lbs EMPTY propane tank and cutting/welding/modifying it with a flat cooking top, chimney ring and door with an adjustable vent.
    So far i think it will be:
    -horizontal...cutting off the front valve end and replacing it with a plate with a hinged door with vent and an ash drawer
    -cutting off a section of the top (horizontal layed) to install a flat cooking sheet
    -cutting a opening toward the back end to weld a pipe ring (to fit a small sized chimney)
    -welding 4 - 1"(?) pipe sleeves (includes a threaded hole with a wing bolt) at the side to lock an adjustable leveling pipe legs into.
    sheet steel would be 1/8" or better?
    Was thinking about cutting a chamfered hole in the cooking flat to sit a pot directly into the fire???
    Bear Clan
    I was born with nothing,
    with hard work and deligence I still have most of it
    this week a lot less...must be a hole in my pocket
    Mar 2008
    Kanata
    979
    Might be moved to making stuff, got turned around and excited with the wall tent thread.
    Bear Clan
