Results 1 to 8 of 8
Thread: Old backpack frame, rusty rivets
    Oct 2017
    Swedish Lapland
    20
    Default Old backpack frame, rusty rivets
    I picked up a neat old backpack with an external aluminium fram yesterday. the straps are in good condition. But, the rivets holding the straps to the frame, in a "layover and around" fashion, so the strap is attached to itself through a loop in the frame. It is fastened by a metal rivet. These rivets are rusting and I don't want to just cut them out either, because I'm affraid of losing strap length and I would rather not have to get new rivets because to me that would mean having to get a special tool and rivets and stuff.
    I would like it to look somewhat nice. I don't have a sowing machine either.
    Ursäkta min Engelska
    43,281
    While a pop rivet is probably your best option (the rivets and tools are pretty cheap here, don't know about Sweden) you could use sheet metal screws, a bolt and nut or even cordage.
    9,678
    Yep, you could remove the old rivets and glue the strap fabric together with a good adhesive while clamping it together using a screw, bolt and a couple of fender washers of appropriate size.
    Leave the bolts and washers place and you should have a strong repair.
    4,953
    Does the rivet go through the frame or stop inside? If it goes through the frame you could use a bolt or Chicago screw. Sounds like the rivet goes through the strap. That should leave a hole in the strap for whatever you’re using. I don’t understand how you would lose strap length.
    Why not just clean up the rivets?.....or are the completely messed up.
    56,518
    A picture might help.
    I second the Chicago screws (we call em something else at work...)
    My suggestion would be to drill out the old rivets and replace them with aluminum pop rivets. I'm sure they have them in Sweden. They're not some obscure regional thing.
    The trick is getting the old ones drilled out. If you don't know what pop rivets are, Google them and find out. Pick a drill bit that is the same size (or the next size up - I would say 1/64" larger, but I know that will mean nothing to you) as the shaft of the rivet, and drill into the head of the rivet until it comes apart. You will have to hold on to the back of the rivet somehow to keep it from spinning when you drill. Take out the pieces and put in a new rivet with a back-up washer. Voila! you're done.
    If you have to buy some rivets and the pop-rivet tool, it's worth it. They are pretty handy, even if you don't use them often. When you need them, they're great.
    Here are some pics (hopefully they will load properly):
    Pop rivet:
    Pop rivet tool and rivets:
    How they work:
    Back-up washers for use with soft materials:
    "The more complex the mind, the greater the need for the simplicity of play." Jim Kirk
